annoying engine knocking!!! NEED HELP
Old Mar 25, 2008 | 08:16 PM
jhe2003's Avatar
I'm not talking about SEAFOAM, what I used was a oil chemical flush, I added it to the engine oil and ran it about 2K RPMs for about 15 to 20 minutes, changed the oil and filter and done.
Old Mar 25, 2008 | 08:33 PM
lady3bglover's Avatar
So today I called the local Chevy dealership and I gave them my VIN for the Chariot. I asked for history of the GM Warranty work that was done. Here's something interesting...
01/30/04 - Oil pump suction pipe and screen assembly replacement
01/30/04 - Lifter, valve - both banks replaced
Both done at 31,184 miles.
I hope this answers some questions.
Lisa
Old May 18, 2009 | 09:32 PM
rubrhammer's Avatar
I know this is an old thread but........ I've had a mild piston slap for several years. Now with 125k on the clock its getting louder. Only when its set over night and not idling. Put it in gear and the load makes it slap. 30 seconds later its gone for the day. Any suggestions?
Bob
Old May 18, 2009 | 09:47 PM
gmc6.0's Avatar
is it a tick noise or clunk???
Old May 18, 2009 | 10:49 PM
budhayes3's Avatar
PT's Slowest Truck
Bob
Sounds like the characteristic piston slap, it's basically the pistons rocking in the cylinders until they heat up and expand, not a whole lot you can do about it. If you say it's gotten louder, the regular piston slap may be combined with some noise from the piston hitting a ridge of carbon that has built up on the top of the cylinder over time. You could try the Seafoam treatment that was mentioned a few posts up, it will help to clean some of the carbon out of the intake, cylinders, valves, and combustion chambers
Old May 20, 2009 | 10:33 PM
rubrhammer's Avatar
Thanks Billy, I hadn't thought about the carbon adding to the condition.
Bob
Old May 29, 2009 | 01:38 AM
There is a TSB for an engine knock/noise at idle.
The main cause is a cracked flywheel according to alldata pro and identifix.
OHsixLS3
Dec 27, 2016 09:30 AM
superchomper2003
Aug 26, 2015 09:39 AM
OHsixLS3
Aug 10, 2015 07:19 PM
04450r
Jul 30, 2015 02:04 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
