Aluminum 5.3
Old Jun 23, 2016 | 09:59 PM
Lowexpo's Avatar
Default Aluminum 5.3
Ok guys, I just bought an aluminum 5.3 shortblock for cheap. Guy thought it was a regular cast '07, it's not. I will be taking it completely apart so question is can how hard is it to swap reluctor wheels? And what would I need to swap to put this in my '07 Tahoe. I was gonna freshen up this shortblock and put my top end on it etc...
Old Jun 23, 2016 | 10:13 PM
Tig's Avatar
Tig
What's the casting on it? You can find out exactly what it is with it.
Old Jun 23, 2016 | 10:52 PM
Lowexpo's Avatar
It has 12572014 on rear and 52072 on front. It has the flat top pistons with cross on them. Had 799 heads the guy said. I have Googled and haven't came up anything other l33 guess because of pistons. And gray sensor so 24x
Old Jun 24, 2016 | 09:55 PM
Lowexpo's Avatar
All right I found it is a L33 12572733 on block. Anybody with reluctor wheel swap info?
Old Jun 25, 2016 | 01:54 AM
1FastBrick's Avatar
Custm2500's Rude Friend
You need the tool from Goodson $$$. RRJ-350
https://www.goodson.com/Reluctor-Rin...allation-Tool/
Old Jun 26, 2016 | 08:59 PM
Lowexpo's Avatar
After gear swap I'm assuming just swap to 58x sensor then I'm good?
Old Jun 26, 2016 | 11:38 PM
1FastBrick's Avatar
No, You need the correct timing gear on the camshaft as well as the front cover with a sensor.
After that you will have to figure out what you want to do with the knock sensors...
Gen 3 such as the L33 have them in the center valley under the intake.
Gen 4 have them on the side of the block.
These blocks have a boss cast in them specifically for the knock sensors whereas the Gen 3 usually does not.
Old Jun 27, 2016 | 08:11 AM
Lowexpo's Avatar
So I'm hoping I can just tap block and put knock sensors in? Obviously I'm new to this.
Old Jun 27, 2016 | 10:36 AM
1FastBrick's Avatar
The Gen 4 blocks have a provision cast into the block for this.
Here is a good comparison of the 2 different blocks.
LS Engine Tips: Gen III vs. Gen IV
It can be made to work for what your trying to do. You just have to be creative.
Old Jun 27, 2016 | 09:14 PM
skolman91's Avatar
That sounds like alot of work, since you got it cheap just get rid of it, ill take it off of your hands..
