Alternator upgrade
Old Sep 7, 2004 | 01:23 PM
02 SIERRA's Avatar
Default Alternator upgrade
Can anyone help me out with a part# for an upgrade? I think i have the 105 amp version now( K68?) At times when I let of the accelerator the lights surge petty bad, also there is always a slight fluctuation at night in my interior lights. Would the alternator be the problem?
Old Sep 7, 2004 | 02:10 PM
therock's Avatar
Default Check Your Connections
Look at your battery connections. Remove them and look. Clean them and make sure they are tight. Follow the wires to where they terminate and check that connection too.
If this is not the problem go to a good battery shop and have them test it. They have never charged me for this. Could also be a bad battery.
Old Sep 8, 2004 | 08:25 PM
shandy294's Avatar
How about possible regulator problem (which is built into the alternator,I believe) . I worked on a friend's Protege (I know,rice) that was getting up to 17.8 volts. You could see the headlights brighten and the engine would even buck. Autozone ,or the like, can check the batt and chg. system. Checking connections ,like they said, is always good to do.
Old Sep 8, 2004 | 08:31 PM
creederado's Avatar
Well if you end up needing a alternator I believe someone posted this a while back.
Seems like a good upgrade.
http://www.alternatorparts.com/ad_al...order_page.htm
Old Sep 10, 2004 | 05:41 PM
02 SIERRA's Avatar
Thanks guys, I went out and looked at the widow sticker from my 03 Yukon and it has an 145 amp alt. this should also be a direct bolt in, correct?
Old Sep 10, 2004 | 05:52 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Correct. Got mine on ebay for $90
Old Sep 10, 2004 | 06:08 PM
02 SIERRA's Avatar
Sweet... Thanks. Remember who you got it from?
Old Sep 10, 2004 | 07:00 PM
No, sorry. I looked on my ebay feedback, but the item number isn't showing anymore. I don't know which username sold it to me. Just try searching
TrickTurbo
Sep 23, 2015 08:41 PM
mpal
Sep 18, 2015 09:12 PM
Noah Burns
Sep 13, 2015 09:28 AM
