Alternator Question
Old Aug 30, 2005 | 11:57 AM
Bradazz's Avatar
Default Alternator Question
I am going to upgrade my alternator to the 03-05 145 amp alternator and I was wondering if would be a direct replacement in my 2000 Silverado. Would I need to change anything to make it work? Thanks
Old Aug 30, 2005 | 02:32 PM
4SHONGO's Avatar
I thought I read that you might have to get the pcm flashed for a bigger alt but I could be wrong.
Old Aug 30, 2005 | 02:34 PM
Bish's Avatar
No PCM flash as I'm running a 210Amp in my Tahoe with no programming change and mine came stock with a 130mp..
Old Aug 30, 2005 | 03:47 PM
BVVHO's Avatar
Bish that 210 Alt. is it an ac-delco. If so what is the part #. TIA
Old Aug 30, 2005 | 04:17 PM
Bish's Avatar
It's a Delphi assembly if I recall but it is rewound for higher current. It is actually a 235amp, not a 210. I got it at Alterstart It has been running strong for a year and about 25K miles. It came with a new beefier cable to run from the alternator to the battery.
THIS is the one I bought.
Old Aug 30, 2005 | 08:56 PM
budhayes3's Avatar
PT's Slowest Truck
I swapped in an 03 145amp alt and it bolted right up, I just had to install a longer belt, part # 12576451. Here's a link to Creederado's Write Up which should definitely be a sticky IMO
**EDIT** I just realized that I did upgrade to the 02 PCM prior to the alternator swap though...not sure if it makes a difference
Old Aug 30, 2005 | 10:52 PM
Bradazz's Avatar
I have already have done the 2002 pcm swap, My main concern was if the plug would work, I noticed on my dad's 2003 Silverado that the plug has 3 wires and my 2000 Silverado has 1 wire. I just want to make sure that it is plug & play.
Idryfly5
Sep 2, 2022 08:55 PM
kalikid06
20
Oct 13, 2015 07:37 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Forcefed81
Sep 8, 2015 10:02 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
