Alot of Problems! Please Help
Old Aug 29, 2013 | 09:12 PM
nsanders504's Avatar
Registered User
when my pump started leaking it would collect a little puddle every night. i could never see up to the leak from the bottom but i would just have a small puddle under the engine every morning.
Old Aug 29, 2013 | 09:34 PM
Jakebrake93's Avatar
Registered User
I will have to check to see if there is a puddle under my truck in the am.
Old Aug 29, 2013 | 09:36 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You need to tackle one issue at a time.
If your loosing coolant, you need to determine were its from and were the coolant is going.
If you have the cracked castech 706 heads you will likely see it mixing with the oil and will usually create a milk shake in side the engine.
The cooling system can be pressurized with a tester to see if and were its leaking from.
As far as your cats, if the engine is throwing a code they have determined there no longer efficient enough and must be replaced.
Don't waste any money on that until you have fixed the mechanical issues with the engine.
If you can't do it or don't have the tools, take it to a reputable mechanic and let them diagnose it for you.
Old Sep 3, 2013 | 07:38 AM
Registered User
Well there isn't any water under my truck and my oil looks fine. Also I've read somewhere that the 02 senors could throw the cat code.
Old Sep 4, 2013 | 03:50 PM
craigsix's Avatar
have your cooling system pressure tested and compressin
o
have your cooling system pressure tested and compression test your engine.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
