Aftermarket trantemp gauge
Old Dec 30, 2004 | 11:50 PM
SnakeOiler's Avatar
Default Aftermarket trantemp gauge
I installed my AutoMeter tran temp gauge a few weeks back and finally got around to doing all the wiring for it today.
I mounted the sender in the pressure port of the tranny. This was the only place I found that was already available for use. I don't believe this is a good place for the sender, since it is not immersed in tranny oil in order to give a proper temp value.
I'm thinking of eventually tapping the pan and installing it there.
What have others done?
Old Feb 13, 2005 | 07:03 PM
SnakeOiler's Avatar
Well, no one ever responded to this, but I do have my answer now that I have Autotap and I can see what's going on.
Based on what I see being logged and what I see on the gauge, I need to relocate to the pan as the pressure port is not reliable. At least not as reliable as I would like it to be.
YMMV
Old Feb 19, 2005 | 08:33 AM
SnakeOiler's Avatar
Ok, I have moved my sensor to the pan, but I'm still showing a discrepancy between the gauge and Autotap. The gauge is showing usually 25-30 degrees cooler.
Why would this be?
Are any of you experiencing this?
Old Feb 19, 2005 | 12:45 PM
Texas Terminator's Avatar
11 Second Club
Why would this be?
seeing a difference between guages is not unusual. keep in mind that the sender for the ECM is actually a physical part of the transmission valve body, it will be subject to heat soak from the metal of the tranny itself. make sense?
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
murderedSS
Sep 27, 2015 10:16 PM
zblee
Sep 17, 2015 07:58 AM
