Aftermarket Radiators
Old Feb 12, 2016 | 11:43 PM
Three6GMC's Avatar
Default Aftermarket Radiators
Who has them and what brand and size are you running? My factory radiator hasn't had any issues with cooling but want to swap over to a thicker aluminum radiator with a fill cap and just curious to see what you guys have come up with.
Old Feb 13, 2016 | 07:38 AM
George C....'s Avatar
Formerly ScreamingL
I have a griffin race one, roughly same capacity as the stock 28 rad of early trucks
I cut their fill cap off and made my own fill neck so rad could be tucked under rad support
Old Feb 16, 2016 | 12:33 AM
Suburbazine's Avatar
I run the Chinese aluminum radiator from ShepherdAutoParts (pretty much the only one in the business of aluminum rads). You can shell out $1200+ for the "high end name brand" cores that offer a negligible performance boost over the Chinese ones for $120.
They don't have fill caps built in but it should be pretty easy to add one to the existing plumbing.
Old Feb 16, 2016 | 07:13 AM
kaze_v8's Avatar
Can you guys post pics of your setups?
Im interested in this as well, ive got a couple Koyo radiators laying around from other projects and was curious to see how hard it would be to make it work on my truck.
Old Feb 16, 2016 | 07:25 AM
03sierraslt's Avatar
Does it work any better then the stock 34"?
Old Feb 16, 2016 | 07:22 PM
tripn88's Avatar
I have this also. Along with 05 Efans. Not sure if it was the radiators doing or my old one was clogged but I was always right under 210. With new radiator Efans and new coolant I was around 180 so I was happy. Looks pretty good too. Single row though.
Old Feb 16, 2016 | 07:45 PM
mike058's Avatar
Highway hauler
Default Don't overthink it
I replaced my 28 inch with a replacement 34 inch core. It was over 90 today in SoCal and my temp never went over 195 climbing hills in overdrive with a/c blasting. You can spend a ton of money if you want, but I like to "keep it simple". Just my two cents.
Old Feb 16, 2016 | 10:40 PM
AlwaysOnKill's Avatar
Ron Davis will make you one .
Old Feb 17, 2016 | 01:03 AM
Tooclean420's Avatar
Registered User
I have an 06 cEw cab Silverado 4wd 1500I'm looking to upgrade my tranny cooler and my radiator 0n a budget with best performance which radiators would be my best bet HELP please
Old Feb 17, 2016 | 01:38 AM
Slightly more efficient than the stock 34" radiator. Before the lowest I could coax the temps to at idle was 179 degrees, now it holds it at 160 degrees steady (unless the AC is on at idle, then it gets heat creep due to insufficient airflow). I think I could greatly improve it at idle with real efans instead of the dual Tork fans I'm running now.
The big thing is the aluminum end tanks with integral oil and trans coolers (I don't use either right now lol). No threat of it splitting or exploding and the welding job is pretty good. The oil cooler will definitely be used for the turbo though . Weight-wise it's about half as heavy as the stock core (I was quite suspicious when I first pulled it out of the box haha).
On the downside...the stock cooler would not cause instant burns if you happened to brush the end tanks or core by accident. This one...I've touched a couple of time by accident and have always gotten blisters. Particularly the radiator support ears on top, the whole thing is solid aluminum and those ears are perfectly positioned for resting arms on...
