Aftermarket intake manifold
Old Jan 14, 2005 | 08:04 AM
Prochrgd5.3's Avatar
Default Aftermarket intake manifold
I was wondering if anyone is using the FAST LSX intake or the Weiand intake manifold. If so how do they fit is it just a bolt on or is there some modification and are they worth the money.
Old Jan 14, 2005 | 08:09 AM
sfj
they should bolt right on and as far as performance i have heard of some performance gains but i believe they were modest at best unless you are running a lot of boost through your SC
Old Jan 14, 2005 | 01:33 PM
bourbeaugmcx's Avatar
i wish someone would do a right up on a swap for us on a truck
Old Jan 14, 2005 | 01:47 PM
According to the book "How to build High Performance Chevy LS1/LS6 V-8s" the FAST manifold makes 7-10 HP on an LS1.
Old Jan 14, 2005 | 02:03 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
...and I think the 6.0L manifold made about 6hp. They did a nice write up here on LS1tech, do a search in the External Engine section.
Old Jan 14, 2005 | 02:13 PM
GEAR M UP's Avatar
If you go with the FAST Intake you'll need to run an F-Body waterpump to relocate the water outlet, and move the idler pulley....
I had the std ls1 truck intake/TB on my 427 with OK results (500rhp).....
I just put on a 90mm FAST Intake and LS2 TB.....
I should have some results soon...
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
