advice on 4.8 to lq9 conversion
Old Aug 19, 2010 | 08:15 PM
silverobo's Avatar
Registered User
Default advice on 4.8 to lq9 conversion
found a bargain 2004 lq9 to drop in my 01 short bed. Problem: pretty sure the lq9 is drive by wire and my 01 is cable. what's my best move? i'm thinking an intake swap and all should be good but not sure if that's the smart thing. issues? performance or otherwise? Been lurking here a while but haven't seen this one addressed.
Old Aug 19, 2010 | 08:18 PM
Mangled03gmc's Avatar
Baltimore Whore
Put a drive by cable throttle body on it..
Old Aug 19, 2010 | 08:43 PM
Formerly 99-2door-08/30/2010
Just use the wiring harness , PCM and throttle body from your 4.8. Get a tune on your existing PCM.
Everything interchanges. A 4.8, 5.3, LQ4 and LQ9 all have the same intake, throttle body size etc.
Old Aug 19, 2010 | 08:53 PM
KleenHall's Avatar
swap the manifold over, its easier
the 04 has returnless fuel system the 01 has a return
there is also different vaccuum conections and the pcv is different
04 do not have the air/egr the 01's have
i did it on my 01' 5.3-6.0
Old Aug 19, 2010 | 09:01 PM
silverobo's Avatar
Registered User
the original pcm for the lq9 is coming with it. my understanding is that it has the capability to automatically adjust to octane changes to a higher degree than my stocker. Anyone got experience with that? seems that would be advantageous, but how much of a hassle is that? worth it? thanks Rob
Old Aug 20, 2010 | 08:44 PM
KleenHall's Avatar
you cannot use the 04 PCM in the 01 truck without changing the harness, its drive by wire
just sell that pcm and get a tune for the 9
gaps
Oct 15, 2015 02:53 PM
whippledstepside
Sep 17, 2015 05:02 AM
vipergtrdj
Sep 11, 2015 05:52 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
