Advantages and disadvanges
Old Jul 13, 2008 | 06:18 PM
Parke10's Avatar
hmm yea im worried about back pressure also,and yesterday when i dove it around like that it seemed to burn alot more gas.. then again that coulda been the fact that i was driving it WOT everywhere
Old Jul 15, 2008 | 12:44 PM
00Silverado's Avatar
The disadvantage is that it will sound like ****, but it can't sound much worse than it did before. Plus, you're from Oildale!
Old Jul 16, 2008 | 08:52 AM
glengine's Avatar
Registered User
I'm running dual straight pipes that go right out in front of my rear passg tire. I think that they sound good.. The only part that kinda sucks is the dronw that you get when your just cruising down the hwy.. I have an 03 6.0l truck and it had duals stock into the muffler and single out.. So i just cut the muffler off and bent some tubing to bring it out the side..
Old Jul 19, 2008 | 09:57 PM
Parke10's Avatar
Hasnt anyone shot yer worthless *** yet?
Old Jul 20, 2008 | 03:49 PM
sprayed8's Avatar
I'm not putting anyone down here, but i was under the impression that the general consensus amongst performance guys was that needing backpressure was a total myth.
Think about it. if youre not worried about running LTs and ORY (way less backpressure than stock cats) then why would you every worry about a short pipe not giving you enough?
I have run open headers with the lts and it ran fine when the 02s werent reading too much fresh air and adding fuel to compensate.
Just my .02, but IMO its gonna sound shitty...CATS SUCK!
Old Jul 20, 2008 | 06:43 PM
nick993's Avatar
you bakersfield punks sure do bitch at each other alot dont you? as for the exhaust, i would run a muff with a straight through design. they say the best exhaust you can get is a full truck length 3" setup.
Old Jul 20, 2008 | 11:45 PM
johnnyh8's Avatar
i know when i was messing around with my exhaust and unbolted it at the y it felt significantly slower down low, then again its a 4.8
Old Jul 22, 2008 | 09:31 PM
Parke10's Avatar
nah only at davids slow 4x4 ***.
Old Jul 26, 2008 | 04:24 PM
jimbobs92rs's Avatar
It will lose power i had a strate pipe on my 06 5.3 it sounded good but it lost power i just cut the muff out and put pipe in place of the stock mufffler.
treyZ28
37
May 16, 2004 02:33 AM
Hit Man X
Jun 3, 2003 02:52 AM
Slowverado
Apr 26, 2003 11:23 AM
ChevyCoonass
Feb 12, 2003 10:47 PM
Ram4Pick
Jun 22, 2002 04:33 PM
