Adding timing chain tensioner/ dampener to LM7?
Old 11-20-2015, 02:32 PM
DeathByNissan55's Avatar
Originally Posted by lxcoupe
Depends. Only way to know for sure is to assemble and turn the motor over to check for chain to cover contact. The oil pump has no affect on this.
My rollmaster adjustable timing set already comes with oil pump spacers and I've read in a handful of places that the 296 oil pump might require grinding as well as the timing cover to fit it all together so I figured that would apply to 295 pump as well.
Trial & Error is always an option, but would rather not waste money ya know? haha
If anyone has literally used a double roller timing set, stock timing cover, and this tensioner kit, with stock or Melling oil pump, on an LM7, I'd appreciate the input.
Old 11-20-2015, 03:42 PM
zblee's Avatar
so the lm7 does not have the bolt holes for a tensioner? any pics of how this trick flow kit bolts up to a lm7 block? i was thinking i just needed the dampener but based on this thread looks like i need this kit too
_Zblee
Old 11-20-2015, 05:14 PM
_Zblee
My LM7 doesnt at least, from 01 tahoe.
If you go to summit website and click on download instructions or something similar, it shows you how to install it and torque spec for bolts and how to install it where.
It looks like the adapter goes on the outside of the cam thrust plate and replaces 3 of the 4 cam thrust plate bolts, then the factory plastic tensioner is pressed onto the adapter as it states in the instructions.
I'm just trying to figure out if double row chain set will still work with this, I ordered it anyways, I'll post once I find out.
Old 11-20-2015, 08:43 PM
Wolftrk99's Avatar
My timing chain was double roller and cane with shims for the pump and all fit behind the stock cover..
5.3Okasai
03-09-2022 01:07 PM
03chevytruck
11-07-2016 04:43 PM
The_W
10-28-2015 09:00 PM
chevyl33
08-24-2015 08:21 AM
Ammadien
07-22-2015 08:50 PM
Quick Reply: Adding timing chain tensioner/ dampener to LM7?
