ACDelco 41-110 Iridium in 2000 Tahoe 5.3L
Old Dec 11, 2018 | 06:28 AM
Ndionano's Avatar
Registered User
Default ACDelco 41-110 Iridium in 2000 Tahoe 5.3L
I switched out the stock plugs during a tune up in June 2018 with AC Delco 41-110 Iridium plugs<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->https://mechanicfaq.com/spark-plugs-for-5-3-silverado/ per the AC Delco book and Rock Auto lookup. Since the tune up, I've always felt the gas mileage has come down. I'm getting 14-15 MPG on the highway keeping it under 70 MPH, when I used to get around 17 MPG. I chalked it up to ethanol fuels.
I just read that AC Delco is no longer recommending this plug for 2000 - 2005 5.3L vortex engines. They are now recommending 41-962 Platinum plugs.
Does anyone have details on why they made the switch? I'm curious to know if the 41-962's are more efficient for this engine and if I should make the switch to the latest recommendation. The $50 cost will quickly be returned if I get 3 MPG back.
Is anyone else running the Delco 41-110 plugs in a 2000 to 2005 5.3L and noticing a drop in fuel mileage?
Thanks.
Old Dec 11, 2018 | 07:13 PM
1FastBrick's Avatar
Custm2500's Rude Friend
From what I found they are cheaper alternative. See the attached PDF
I believe the original plugs where 41-985 Platinum with a .060 Gap. This was discontinued and replaced by the 41-110
41-110 is Iridium With Recommended .040 Gap
41-962 is Double Platinum With Recommended .040 Gap
File Type: pdf
Old Dec 13, 2018 | 10:52 PM
swathdiver's Avatar
5 Year Member
I read a lot of posts about folks complaining about reduced mileage when using those 41-110s. This was even with folks that originally used the 41-985s pre-gapped to .040" too.
I lucked out and bought a brand new box of 41-985s so I have no experience with the newer ones!
91RS
Feb 11, 2013 06:14 AM
boydcoz71
Sep 23, 2012 07:02 PM
viciousknid
Nov 4, 2010 07:38 PM
1SlowHoe
Sep 9, 2006 06:41 PM
