Which AC oil filter?
Old Apr 14, 2004 | 02:36 PM
Sportfish's Avatar
Default Which AC oil filter?
I just changed the oil in my 03 Silverado 5.3 for the first time and found the AC Delco PF46 to be a real PIA to remove and replace due to its small size. I don't like small filters anyway and am concerned about flow capability. I found that the 02 models used a larger PF59, but the AC Delco site shows this filter application ending with the 02 models. Is there any reason I can't use the larger PF59 on my 03?
Old Apr 14, 2004 | 02:57 PM
LOW2000's Avatar
In a word...no.
Old Apr 15, 2004 | 06:48 AM
Sportfish's Avatar
Originally Posted by LOW2000
In a word...no.
In a few more words, could you explain why...as far as I can tell, the 2002 has the same 5.3 as the 2003.
Old Apr 15, 2004 | 09:45 AM
In a word...no.
Low is 100% right
Use the PF 59 - I changed mine as soon as I got it home
Reason GM uses a 44 vs the 59 - I am not sure
The 59 also has an anti drain back valve if I am not mistaken.
Unsure of the 44
Old Apr 15, 2004 | 10:05 AM
Sportfish's Avatar
Thanks. I misunderstood Low's response in that I thought he meant it couldn't be used, but I did ask if there was any reason I can't use it, so I assume he meant no, there isn't. The only reason I can guess why the change is perhaps ground clearance, since the 59 would extend below the oil pan. But that would be a long shot to hit the oil filter and nothing else.
Old Apr 15, 2004 | 01:03 PM
LOW2000's Avatar
Go to the auto parts store and see which costs more, there is your answer.
lukn4trbl355
Oct 21, 2015 11:19 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
cousblake11
Sep 9, 2015 06:52 PM
