About to swap oil pump in 2500hd 4wd... any advice?
I've read a few threads about not being able to get to the oil pump tube bolt in some of the 06-07 4wd trucks. I've seen on you tube a guy cutting a tab from the back of the tube so the flange could pivot to the outer bolt hole when installing. Well what is going to be my best bet for doing this. How about loosening the oil pan bolts and dropping it down some, will it clear that way? Thanks
Ferocity02
Jul 17, 2015 07:05 PM
