? about the ecm and gears
Old Jun 8, 2005 | 06:41 PM
MR.QUIK's Avatar
Default ? about the ecm and gears
If i am running the nelson tune that is set up for the 4.10 gears and now switch to 3.73 do i have to retune or can i run it like that
Old Jun 8, 2005 | 10:28 PM
OUT2WIN's Avatar
I dont think it will matter. The mph will be off but it shouldn't be a big deal
Old Jun 9, 2005 | 06:14 AM
BigBlackAv's Avatar
your speedo and odometer will read 5-10% low. Meaning, when driving 60 your speedo will say 53-54...if it is a drastic gear change it will cause havoc w/ the bcm and you will get ABS and brake codes....other than that, the it won't matter....You should see a little better mileage, and a little slower off the line...or did you switch to smaller tires at the same time?
Old Jun 9, 2005 | 02:08 PM
MR.QUIK's Avatar
no same tires but how about rpm like shifting points
Old Jun 9, 2005 | 11:01 PM
BigBlackAv's Avatar
No change...doesn't matter what the wheel speed is ... just r's and that won't change w/ changing the gears in the tune.
Old Jun 10, 2005 | 12:42 AM
MR.QUIK's Avatar
cool so i can go to the track this weekend and shift at the same r's as b4
Old Jun 10, 2005 | 01:46 AM
one03sierra's Avatar
Formerly one92rs
Talking
it all depends on how it was set up. the r's are going to read different and will in effect cause the shift points to be off. the pcm uses speed as well as rpm to shift the trans.
mzoomora
Jan 3, 2016 07:06 AM
lxcoupe
17
Aug 26, 2015 05:00 PM
ou812sm
Jul 28, 2015 08:24 AM
oharajo
Jul 18, 2015 09:24 PM
Nimoryan
Jul 5, 2015 03:50 PM
