9psi on a 4.8?
9psi on a 4.8?
i have the 2.7" powerdyne pulley ready do go in along with begger injectors. this pulley is said to make 9psi, does anyone see any problems with this set-up, i think i should be fine. thanks
FormerVendor
Tribe Shaman
the bypass valve that came with the kit is only good for about 6 psi, it wont last long at 9,
so start hunting for a better BOV.
42 lbs injectors will work just fine at 9 psi.
find a local shop and do a dyno tune, after it is all done go hunting for a hemi and have some fun.
11 Second Truck Club
If it is "supposed" to have 9 psi then it will prob be around 6, at least that has been my experience with Powerdyne. Get the boost up around 8 or 9 psi, get the tune right, and I think you will be happy with the results-the Powerdyne heats the air far less than some other blowers and it is capable of making some good power.
i am going to run 36lb pontiac gtp injectors, thats what the guy told me to use that is going to tune my car. which BOV are you using at this PSI, and are they hard to swap out, do they perform better? thanks
11 Second Club
you will be ok, but an injector upgrade is definately needed. 36's would be fine for what you are doing, just don't try to run the truck without tuning for the new injectors.
