99 Sub 5.3 - FAST LSXRT 102 : Injectors question
Old Feb 23, 2015 | 10:02 PM
GREENSIERRA's Avatar
I had the same problem and bought different injectors that did fit. try taking the oring out and seeing if it still doesn't fit, the problem with mine was the plastic clip under the oring was to big and wouldn't allow the injector to go in. FIC said it was fine to just take the plastic ring off cause of the way the injector hole in the intake was but I decided to just get new injectors instead.
also make sure you are running the right oring, should be orange I believe
also the tune would need to be adjusted with different injectors
Old Mar 26, 2015 | 08:10 PM
jocuzz's Avatar
yep ls2 injectors and plug adapter needed for mine too. then it fit perfect. watch those plug adapters though, the pins can be pushed in too far and won't run right.
TA63
Mar 29, 2016 04:38 PM
jdb11386
Dec 3, 2015 09:34 PM
Sexyrado327
Aug 2, 2015 04:08 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
