99 7.4, 454 ?
Old Apr 17, 2007 | 01:20 AM
  #21
I can say without a doubt mine is lots more than 410 with Jesse's tune. I would bet any decent tuner can make more power than Hypertech's handheld. So if they made 40 more hp @ 3750 and 60 more lb/ft of torque at 1000 rpm! And tons extra everywhere in the powerband.
Check out these stock figures from Hypertech on the 8100 vs the 7400. Initial grunt the 7400/454 will do better than the 8100!
EDIT: I have added 02-06 8100 and 02-06 6.0L. Much different. The 7400 will still cream a 6L in towing, but the 8100 is king (as it should be). Now, diesels......
http://www.hypertech.com/get_dynocha...1371574&tp=pdf
http://www.hypertech.com/get_dynocha...1303434&tp=pdf
After seeing these graphs I don't see how a 8100 is really worth much over a 7400 at all, only slight bit more power at some rpms that you rarely NEED to go up to unless you are on it.
Originally Posted by Wide Open
I miss my 97 454 sometimes. I know it was only rated at 410lbs but it sure felt like a lot more. As has been said dozens of times above it would pull anything. I once pull started a concrete mixer at a job site when the driver burned up his starter motor trying to crank the engine over with the drum engaged.
Usually average about 14-15 unloaded and about 12 towing. High mpg was 16 and low was 9 pulling a 10,000 lb John Deere.
SS94S10
Jan 3, 2019 01:57 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
gmcyukon
Sep 11, 2015 10:33 AM
chvy=power
Sep 8, 2015 11:06 AM
