99 7.4, 454 ?
Old May 25, 2006 | 03:18 PM
Kerr's Avatar
Default 99 7.4, 454 ?
Why is you dont see any parts listed for the 454 trucks. I have been in the market for a 8100 for some time, but the bank just got in a repoed 99 model with 454.. if its cheap i was thinking i might go with that, but there does not seem to be anything listed for it on line. Any reason for this or am i just looking in the worng spot.
Old May 25, 2006 | 03:22 PM
Try looking under a 98 model, 98 and 99 are the same truck.
Old May 25, 2006 | 03:57 PM
Kerr's Avatar
thanks ill give that shot.
By chance do you remember what the hp / tq was.. My friend said he thought they where like 230hp and 300lbtq.. seem real low for the amount of cubes.
Old May 25, 2006 | 04:48 PM
Those are for the 350 not the 454. I think the later 454 are rated at 300-330 hp and 450 ft-lbs. I know the 502 retro engine is rated at 320 hp and 515 ft-lbs and the 94 454 is rated at 300 hp and 400 ft-lbs.
Old May 26, 2006 | 08:35 AM
Kerr's Avatar
so there is not a lot of difference in the "old" 454 and the "new" 496. in terms of hp and tq.
Old May 26, 2006 | 10:15 AM
That's a Vortec 7.4,I had one in a 96 Suburban 9.6to1 compression with good fuel injection ran about the same as a stock 5.3 performance wise,but you'll be lucky if you get better than 11mpg.
Old May 26, 2006 | 10:45 AM
Actually that is quite good for a 4 ton beast Suburban to keep up with 5.3. My dad had a GMC Dually which was not fast at all but could pull just about anything, damn manual. The most this truck ever saw was 28,876 lb, and that was towing a 9 ton cougar cage, and the goose neck flat bed was the rest, on this particular trip of 150 miles the truck averaged 6 mpg at 55 mph.
Old May 26, 2006 | 12:42 PM
PSM's Avatar
PSM
290 horsepower @ 4000 rpm and 410 foot-pounds of torque @ 3200 rpm i believe... and i think the CR was only like 8.9:1... it was very choked up
Old May 26, 2006 | 03:09 PM
Kerr's Avatar
do they make blowers and stuff for these trucks like the they do the 8.1 i googled it with no luck.
Old May 26, 2006 | 03:36 PM
Yes they do, Whipple makes a kit.
