99/02 pcm swap
Old May 9, 2005 | 09:59 PM
  #21
Wilde Racing's Avatar
How do I change this text
yep 2002, but you 2 Vehicle Types to choose from.
Old May 9, 2005 | 10:13 PM
  #22
bigredexpress99's Avatar
yeah, i understand that I have 2 vehicle model years to choose from, just wasnt sure if I would need a 99, especially with all the other computers in the truck....thanks, now I know.
Old May 9, 2005 | 10:45 PM
  #23
gonzo 6.2's Avatar
no real answers yet
Old May 10, 2005 | 01:48 AM
  #24
negativeswitches's Avatar
anyone know if i have a westers tune and wanted to reprogram it if they will let me use an 02+ tune by paying the core charge difference or if i can ebay a pcm and send them that one?
-Erik
Old May 10, 2005 | 04:57 AM
  #25
jlwz71's Avatar
Using edit, I just copied and pasted the 02 tables. Runs great.
Old May 10, 2005 | 09:40 AM
  #26
gonzo 6.2's Avatar
Thanks J
So would that be the same as a 02 vin flash?,that is what im considering doing with a spare PCM which is my OE 00 PCM that has a ED W. locked tune in it.I was thinking of having it flashed with a 02 Vin and use my Edit that I have yet to use.
Old May 10, 2005 | 10:06 AM
  #27
BigKID's Avatar
I copied over some 02 tables into my 00 file as well and it is working fine but it did not remedy the false knock issues I had till I started playing with the knock settings. From my understanding, the tables are mapped in different locations on the 99-00 than the 01-02 so you can't simply flash an 01-02 .ls1 file onto a 99-00 pcm or viceversa. As for using a tech2 at the dealership to flash in a later vin, I dont know how that works.
Old May 10, 2005 | 10:13 AM
  #28
gonzo 6.2's Avatar
Yes bigkid
This is the info im after before I send out my PCM, Or I can get a 01-02 core pretty reasonable and then do a vats relearn and then try edit.
Old May 10, 2005 | 07:19 PM
  #29
Originally Posted by gonzo 6.0
Yes bigkid
That is the way I am gonna go more than likely, seems to be the easiest and "proven" method. That way I wont have to worry about still tweaking it to get rid of the kr*, it will (should) be gone with the truck running on the 02 tune!
Old May 10, 2005 | 08:58 PM
  #30
jlwz71's Avatar
Yeah I had to monkey with the knock sensor settings A LOT. My wife thought I was having an affair because i would flash then drive and log. Gone many a night but I finally got it.
