95 Sub. need help w/LS1 fan install??
I have some LS1 fans that I want to install in my 95 Sub. Has anyone done this? I know the new ones have kits for the wiring but I'm not sure on the 95'. What would be the easiest way to do this??
Thanks
Thanks
I have my LT1 fans on a 30A switch. Mainly because the thermo-switch burnt up. I can turn them off or on when I want. Which is usually when I get in or out of the veh. I don't mind, and can't forget them, they're loud!
Originally Posted by Arigom
Does anyone make a kit which can be computer controlled? My wife drives the Sub. It would be better if she didn't have to remember to turn them on.
The only slight compromise I would suggest for this application, though, is to use a 160 thermostat in manifold because if you use a 180 thermostat,the fans will be running a lot...
if you need help wiring, i can put together a basic scematic for this setup for ya...
A schematic would be great!! I have to admit I'm not much of an electrician. Do you happen to have a part number from Summitt? I agree with not wanting to run a probe.
The relay and switch kit for $50
Or the switch alone for $28
I'll draw up a schematic later and post it.
