90mm Throttle Body solution for 6.0L Vortech
Old Aug 31, 2007 | 11:28 PM
Bismarck's Avatar
Default 90mm Throttle Body solution for 6.0L Vortech
Guys, anyone know of a 90mm Throttle body solution that will work with the 2006 6.0L?
The corvette T-bodies do not have the right connector.
Thans
Old Sep 4, 2007 | 10:45 AM
SS_bnoon_SS's Avatar
You have to perform a swap to get the Corvette one to work. Use a Dr X harness (search for his user name on here). There is no bolt-on 90mm solution that will not require an adapter.
Which manifold are you going to go with? Car intakes require a bit of fabrication to use as well...
Old Sep 4, 2007 | 12:24 PM
thunder550's Avatar
High on diesel fumes
Regardless of what throttle body you use, you will have to swap intake manifolds.
blownss27
Aug 14, 2020 08:27 AM
mikeyjm1
17
Oct 29, 2015 11:04 PM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
chvy=power
Sep 8, 2015 11:06 AM
