90mm TB Swap...Questions
Old Jan 22, 2011 | 07:00 PM
Phantom's Avatar
11 Second Club
Default 90mm TB Swap...Questions
Just making sure I'm right here...To swap a 90mm Tb to our DBW vehicles, requires any kind of 90mm tb we can find, and the Dr X harness and thats it? Other than the intake of course...
Or is there any 90mm tb that is a direct bolt on and go for us?
Old Jan 22, 2011 | 07:48 PM
zachm89's Avatar
Yes, you will need a 90mm throttle body, dr x harness and some kind of 4 bolt intake for the new tb. Most people go with a tbss intake manifold and tb swap because it is a direct bolt on. A 90mm tb will not work with your stock 3 bolt manifold unless you can find a 3-4 bolt adapter which would probably cost the same as buying a tbss intake and not really net any gains.
Old Jan 22, 2011 | 08:46 PM
dirt track racer 81's Avatar
He's gettin rid of the stock intake but not running the tbss intake
Old Jan 22, 2011 | 08:55 PM
terravast4's Avatar
or you can run an o2 tac module with a 90mm wire harness adapter
Old Jan 23, 2011 | 10:34 AM
andrew383's Avatar
traveling mod
IF i remember roight the car TB's open the opposite way..The maggie tbssers used the ls7 to fix throttle issues..
Old Mar 7, 2011 | 06:07 PM
Phantom's Avatar
11 Second Club
Could you explain this a little more?
Old Mar 7, 2011 | 06:10 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
the guys with the TAC mod were having problems getting 100% from the TB, hence the need for the X-link which if you go to torquerush dot com you can see what TBs are compatable I believe. It's been a long while but take a looky.
SS94S10
Jan 3, 2019 01:57 PM
natejk
Nov 15, 2016 08:05 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
