862 & 317 compression ratios
Old May 15, 2006 | 01:47 PM
Default 862 & 317 compression ratios
I was going on the info that the 317 heads will lower my compression ratio over the stocker 862. But since i came across the head casting info put out by JRP, it showes different. I see that the all volumes and diameters are bigger on the 317 which is what I want for more flow. but the 317 has a c/r of 10:1 versus the 862 with 9.5:1. The statistics info I was told was wrong. I want the 317's for better flow so what will I have to do to lower my c/r for boost?
Old May 15, 2006 | 02:14 PM
The 317 heads have a 72cc chamber and I beleive the 862 heads have a 65cc chamber.The 317 heads used on a 5.3 block will have about 8.7 to 1 compression.
Old May 15, 2006 | 02:58 PM
tdrumm's Avatar
862s have a 61cc chamber. There are many more variables to SCR than just chamber size, although it does play an important role. All other things remaining the same, replacing a 862 head on a 5.3 with a 317 head (larger chamber volume) will drop the CR like whitt1 said.
Old May 15, 2006 | 04:48 PM
thanks guys I just wanted, to reconfirm thats all. I have all the statistics on the heads but wasnt sure how the c/r drops and now I know
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 3, 2015 11:03 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
