862 & 317 compression ratios
I was going on the info that the 317 heads will lower my compression ratio over the stocker 862. But since i came across the head casting info put out by JRP, it showes different. I see that the all volumes and diameters are bigger on the 317 which is what I want for more flow. but the 317 has a c/r of 10:1 versus the 862 with 9.5:1. The statistics info I was told was wrong. I want the 317's for better flow so what will I have to do to lower my c/r for boost?
862s have a 61cc chamber. There are many more variables to SCR than just chamber size, although it does play an important role. All other things remaining the same, replacing a 862 head on a 5.3 with a 317 head (larger chamber volume) will drop the CR like whitt1 said.
gmcyukon
Oct 3, 2015 11:03 PM
