85MM Throttle Body on LS1 Intake
Old Dec 4, 2006 | 11:35 AM
dirt track racer 81's Avatar
Default 85MM Throttle Body on LS1 Intake
So will a 85mm throttle body fit on a ls1/ls6 intake? currently i have a ls1 intake on my truck with the stock throttle body and plan on goin to the ls6 after the 1st of the year..and i was just goin to see if it would be worth going to the 85mm throttle body.i can get them for under 200 dollars where i work..
Old Dec 4, 2006 | 11:58 AM
BlownChevy's Avatar
blownerator
25 Year Member
i do not think the inlet on the intake is 85 mm, I am pretty sure they use an adapter that negates the 85mm TB upgrade IMO.
Old Dec 4, 2006 | 12:07 PM
could the intake be cut away for the blade to open?
Old Dec 4, 2006 | 04:05 PM
Quik's Avatar
5 year bitches!
they do a conversion for the LS6 itnake that uses a LS2 opening. honestly man your truck doesnt need it. you just dont have enough motor
Old Dec 4, 2006 | 04:29 PM
ill stick with what i got..read some other things about the inside of the intakes..
Old Dec 4, 2006 | 04:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
What would support a comment like that? Did you consider that there might be possible mods in the future that will require the mod?
Old Dec 4, 2006 | 04:56 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You dont need a 408 with a super secret cam and L92 heads to make use of a better intake
Old Dec 4, 2006 | 05:45 PM
from some of the stuff ive read the inside of a ls1 intake is 78mm..i dont know about the ls6..can this be ported out on the inside of the intakes?
Old Dec 5, 2006 | 08:48 AM
lol.....I'm with you on that one Slow!
Old Dec 5, 2006 | 04:46 PM
Quik's Avatar
5 year bitches!
its not benefical to do it honestly.
as for my statement it came off wrong but the fact is he doesnt need 85mm of TB for his setup.
and lets not point fingers at builds or motors. cause im sure your history 1slowZ71 will give us plenty of hours of entertainment
