8.1L conversion
Old Dec 28, 2006 | 11:07 PM
Default 8.1L conversion
Does anybody have information on an 8.1L conversion into a 1/2ton 99-07 gm truck what do i need what parts are needed to complete swap amd what mods do i have to do.......
Old Dec 28, 2006 | 11:12 PM
i'm pretty sure it is very difficult. I am also unsure as to if the motor will even fit between the frame rails. might I ask why you are converting to the big block?
Old Dec 28, 2006 | 11:13 PM
dirt track racer 81's Avatar
i would stay with a small block..
Old Dec 29, 2006 | 07:11 PM
My Friend Wants To Try Something Diffrent In His Project
Old Dec 29, 2006 | 07:14 PM
i dyno'd a stock 8.1 the other day..made 18x rwhp..a stock 5.3 makes 215-220
Old Dec 29, 2006 | 08:37 PM
v8
17,16,15,14,13,12,11 Drvr
thats because of the 4l80 transmission it eats up 50hp over the 4l60
Old Dec 29, 2006 | 08:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
DOnt forget the big *** 11.5 14bolt
Old Dec 30, 2006 | 02:13 PM
Manic Mechanic's Avatar
My 7,000 lbs. 2500HD with the Allison was running over 85 MPH in the quarter mostly stock. Safe to say it had over 200 hp. If you don't change the fuel filter on a 8.1 every 25K you'll loose a lot of power in no time. Not to mention plugs, etc. The PCM tries it's damnest to prevent the 8.1 from raising hell also. If you don't test in Tow/Haul to lock the converter you'll never get a good reading. Also all the torque management in 1st and 2nd gear.
Tie Rod had his dyno'ed with a CAI, HyperTech, and mufflers and put up 285+ at the wheels.
My 8.1 powered 2500hd 4x4 ccsb with a bunch of heavy crap on it smokes small block and diesel powered stuff all the time. Should I put a small block in it to go faster?
https://www.performancetrucks.net/fo...ight=big+block
Vernon
Old Jan 2, 2007 | 09:38 PM
ChevyMan23's Avatar
http://video.performancetrucks.net/v...85bfb6394e.htm check this 8.1 out..i know its from here....but damn hes quick
Old Jan 2, 2007 | 10:03 PM
TieRod's Avatar
That would be me. I have a turbo on it now!
