8.1L conversion
Does anybody have information on an 8.1L conversion into a 1/2ton 99-07 gm truck what do i need what parts are needed to complete swap amd what mods do i have to do.......
My 7,000 lbs. 2500HD with the Allison was running over 85 MPH in the quarter mostly stock. Safe to say it had over 200 hp. If you don't change the fuel filter on a 8.1 every 25K you'll loose a lot of power in no time. Not to mention plugs, etc. The PCM tries it's damnest to prevent the 8.1 from raising hell also. If you don't test in Tow/Haul to lock the converter you'll never get a good reading. Also all the torque management in 1st and 2nd gear.
Tie Rod had his dyno'ed with a CAI, HyperTech, and mufflers and put up 285+ at the wheels.
My 8.1 powered 2500hd 4x4 ccsb with a bunch of heavy crap on it smokes small block and diesel powered stuff all the time. Should I put a small block in it to go faster?
https://www.performancetrucks.net/fo...ight=big+block
Vernon
Vernon
http://video.performancetrucks.net/v...85bfb6394e.htm check this 8.1 out..i know its from here....but damn hes quick
