8.1 Guys - Please step inside....
Old Jul 21, 2009 | 11:37 AM
69MyWay's Avatar
Default 8.1 Guys - Please step inside....
Need to know what applications the 8.1 came in that had the a/c compressor mounted HIGH on the driver side.
Also need to know options for clutch applications to bolt the 8.1 with a stock 8.1 flywheel to an older GM trans.
ANY HELP YOU CAN GIVE - links...pointers...are all good.
Old Jul 21, 2009 | 04:34 PM
TieRod's Avatar
High mount A/C I think is an RV application. I found some pics of 8.1 in Kodaks and Top Kicks and the compressor is high on the pass side.
Any big block neutral balance flywheel will work on the 8.1l. As far as clutch options on a stock 8.1 flywheel I cant help.
Old Jul 22, 2009 | 06:31 AM
69MyWay's Avatar
Very cool! This info helps very much.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
