60lb. injectors
Old Feb 14, 2008 | 04:48 PM
melon07's Avatar
Default 60lb. injectors
I'm doing a turbo 6.0L project and will need 60lb. injectors. what m i looking to spend, and where can I get some? thanks
Old Feb 14, 2008 | 05:46 PM
03sierraslt's Avatar
425-500 depending on the vendor, this factoring in injectors, plugs etc.
You have a PM.
Old Feb 14, 2008 | 05:51 PM
Mangled03gmc's Avatar
Baltimore Whore
Check over on tech also, I have seen them floating around over there from time to time, but look to spend 400+ on them
John
Old Feb 14, 2008 | 05:53 PM
I see this is going in a 93 camaro correct? If so what wire harness do you have? Truck or car harness. I am just asking because if its the truck harness youll have to change out the Injector clips. If using the truck harness the injector plugs needed are Part# MSD-2400 from summit or elsewhere.
Old Feb 14, 2008 | 06:07 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I found mine for less than $300 used. Racetronix if looking for new ones.
Old Feb 14, 2008 | 07:18 PM
melon07's Avatar
I'm keeping the camaro harness for lights and other basic stuff. The ignition will run on msd and the rest will run on a megasquirt. similar to parish's 5.3 build if you know anything about that (the fairmont, NOT the truck)
Old Feb 14, 2008 | 07:28 PM
Ok and yes haha, well I guess you should be covered then.. Just get yourself some injectors.
Old Feb 14, 2008 | 07:31 PM
melon07's Avatar
what should i use for a fuel pump? i have no clue how big of one i need... thanks for the help
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
