6 Speed Bolt on Questions
Old Apr 17, 2005 | 07:55 PM
xrevx1's Avatar
Default 6 Speed Bolt on Questions
What years would work to bolt on a 6 speed transmission? On a 2000 silverado 4.8 manual transmission?
Old Apr 18, 2005 | 06:56 PM
TURBO8's Avatar
Any info on this subject, I am trying to put together the same project. Neeed alittle help. Ok, alot of help.
Old Apr 18, 2005 | 07:24 PM
jmproductions's Avatar
I was asking about this and I have been told that the clutch disc will need to come from the 6-speed due to a different spline but the clutch linkage will hook up ok. It will mount to your crossmember with no problems at all, but you will need a shorter, custom drive shaft made. Gearing will be drastically taller so you will want to drop down to at least a 4.56. Remember this is 2nd hand info from a guy on here who did it, but I think he knows what he is talking about. I think I'm gonna hold on to my 5-speed until I get sick of rebuilding it, but the 6-speed it tempting because of the ability to change ratios.
Old Apr 18, 2005 | 07:31 PM
xrevx1's Avatar
I think that I am sick of the buying transmissions. Due to the mishap over the weekend of snapping drive shaft. I am just going to replace the transmission now and get the new customs shorter drive shaft made. So your saying that I need the new clutch disk but, everything else will work?!! I have 373 gears anyway so I would be good on that.
Old Apr 18, 2005 | 07:57 PM
TURBO8's Avatar
I think 1truess said that the stock 4l60 drive shaft worked fine. The 6 speed and the 4l60 was the same length. Finally some info on this swap. I've got a hard on.
Old Apr 18, 2005 | 07:59 PM
xrevx1's Avatar
Same here rock hard.
Old Apr 22, 2005 | 08:20 PM
Not sure if the 3.73 will be low enough that's quite a bit taller than a 4.56. 6gear is the guy who has actually done it, so you might want to PM him for more info.
thewrx
Aug 12, 2015 08:28 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
grantpo
Jul 15, 2015 12:21 PM
