6.2 questions.
Old Jul 8, 2009 | 12:10 AM
chevytruckguy's Avatar
Default 6.2 questions.
I can pick up a 09 6.2 from an escalade with 9k miles, but its just the block and heads. Will I be able to use my 06 4.8 intake, coils, and front timing chain/cover to make the 6.2 work? I'm thinking I might have to buy another cam, and get bigger injectors, but does anyone know for sure what else is involved?
Old Jul 8, 2009 | 08:22 PM
charcoal03silvy's Avatar
Not an expert but i would think not. Or atleast not run very well
Old Jul 8, 2009 | 08:26 PM
andrew383's Avatar
traveling mod
id just get the 90mm intake for it..
Old Jul 9, 2009 | 08:10 PM
Petraszewsky's Avatar
No the 4.8 intake will not work on L92 heads...as they are rectangular intake ports not cathedral style..You'll need a L92 truck intake or LS3/L76 intake fuel rail and injectors....your coils will work though...4.8 timing cover/chain won't work as the L92 uses a front mounted cam sensor...
Old Jul 9, 2009 | 08:48 PM
Bo185's Avatar
Plus you need a converter box for the 58x reluctor wheel. You could use the LS2 timing cover, gear, and sensor. And just extend the cam sensor wires as well as the knock sensors.
Old Jul 10, 2009 | 01:01 AM
thanks for the info and advice. I'll be passing on that.
Skip Fix
22
Jul 9, 2016 07:08 PM
Jonblarc7
40
Dec 23, 2015 10:15 PM
BCraven1018
Oct 1, 2015 08:22 PM
OHsixLS3
Sep 25, 2015 04:38 PM
