6.2 cam and DOD delete
Old Sep 22, 2019 | 08:05 PM
AndysC3's Avatar
Default 6.2 cam and DOD delete
I'm getting ready to install a comp vvt cam in my 2011 Escalade. It's a 214/226 .500/.500 115+6LSA. Plan on upgrading the springs. Probably a set of PAC 1219x. And a DOD delete from Texas speed using the ls9 head gasket. Unless theres a better head gasket I should use. Also going to do some long tube headers. Probably a set of speed engineering 1 3/4 and ory. I know they'll require some modifications but that's fine with me. Should I upgrade the pushrods? I have a set of comp 7.375 from my Sierra build. Only plan on running it up to around 6300rpm. Any thing else I should look into? I'll do the tuning with my efi live and a wbo2 is on order as well.
Old Sep 23, 2019 | 12:18 PM
Drspencer's Avatar
5 Year Member
The mild lift would lead me to say no need to change the pushrods unless you need a different length.
Old Sep 23, 2019 | 02:14 PM
AndysC3's Avatar
I'm also switching to comp lifters and not sure if they require a different length pushrod like the ls7 lifters can
Old Sep 23, 2019 | 03:34 PM
kaze_v8's Avatar
Yep lifters are a must.
I went with Morel lifters on stock length pushrods
1CAMWNDR
11
May 28, 2018 08:56 AM
SHEHABI93
Dec 10, 2014 01:39 AM
Gm_max1500
May 22, 2014 12:13 PM
richrich
Jan 27, 2014 07:40 PM
Alan6_0
Jan 30, 2013 12:19 PM
