6.0's and LS6 heads....
Old Nov 10, 2004 | 04:14 PM
StreetSweepa's Avatar
Default 6.0's and LS6 heads....
Do the 6.0's have ls6 heads?
Old Nov 10, 2004 | 04:17 PM
no, they are close but they have bigger exhaust and intake valves I believe.
Old Nov 10, 2004 | 04:52 PM
Yelo's Avatar
Valve size is the same, Chambers are larger but the design is almost identical, Intake ports are exactly the same, and Exhaust ports are exactly the same
Old Nov 10, 2004 | 04:56 PM
moregrip's Avatar
what a rush!
yep
Old Nov 10, 2004 | 06:21 PM
gonzo 6.2's Avatar
valves and springs are different.
Old Nov 10, 2004 | 11:15 PM
Yelo's Avatar
True....the LS6 uses hollow sodium-filled valves and different springs, BUT....the valve size IS the same as the 6.0 heads
Old Nov 10, 2004 | 11:16 PM
gonzo 6.2's Avatar
Yes,same size valves
Old Nov 11, 2004 | 05:45 AM
02Reaper's Avatar
I think the ls6 heads still flow a little better than the truck heads. There is a chart on here that has all the info. It is in the internal section.
Old Nov 11, 2004 | 07:01 AM
Sport Side's Avatar
-Same valve diameters. 2'', 1.55''
-Larger combustion chamber (6.0)71cc, (ls6)64.45cc
-LS6 runner volumes 210cc, 75cc,
-Flow @ .600 lift = 257cfm, 183cfm (ls6)
-Flow @ .600 lift = 240cfm, 177cfm (6.0)
There are some differences. I don't have the runner volumes for the 6.0L
Old Nov 11, 2004 | 08:43 AM
SEE I TOLD YOU GUYS i DIDN'T KNOW WHAT i WAS TALKING ABOUT. THANKS YELO
