6.0l tune
Old Mar 7, 2005 | 09:06 PM
Default 6.0l tune
does any one have a tune for a 6.0l so far the most ive got to the wheels is 250hp and 290tq with a 2004 6.0 i used edit and copied and pasted the fuel and spark from a 2003 6.0l ss silvarado i just know i can get more power from this thing just wondering thanks
if any one has a tune that will work it will be greatl
thanks for the help
btw its in a 2000 gmc 1500 ecsb w/4l60e
Old Mar 7, 2005 | 09:13 PM
Flyer's Avatar
Is there a 6 in this truck, if so, which 6 is it? If it's an lq4, there's a lot of spark left in it which will make a big difference.
Old Mar 7, 2005 | 11:23 PM
smokeydoge's Avatar
Wester has a tune for it. That motor has a lot left in it. In an extcab I bet it'd haul *** !!
Old Mar 8, 2005 | 07:05 AM
one03sierra's Avatar
Formerly one92rs
Talking
are you using edit?? hptuners? either way there is a lot to change and gain performance with. i would begin by adding some timing to the upper rpm's on the table. man i can go on and on. and if you are planning on buying a tune there are sponsers that do kick *** tunes.
Old Mar 12, 2005 | 03:58 PM
im using ls1 edit its a lq4 out of a 2004 4x4 2500hd truck i used the tables out of a stock 2003 ss truck that i downloaded from ls1edit.com when i took it out on the highway the truck pulled hard i had the spedo pegged out and the tach was at about 5000rpm (some where around 130) i let out cause the truck started to float but the motor was pulling hard still
Old Mar 12, 2005 | 06:32 PM
jimmyblue's Avatar
From what little I've seen of trucks, there is a lot of spark
left out, the PE is applied late and slow, burst knock is so
sensitive that it gets applied during normal acceleration.
I don't know if Edit can read "straight" binaries like the
HPTuners .bin (which is unencrypted like honest software
should be). But if so you might want to take a look at all
the .bins on Horist's repository site (see sticky). If this
doesn't work for you, I'd look to the late F-body tunes.
If you post "gimme tables" requests in the PCM section I'm
sure you could get plain-text examples of other platforms'
key tuning tables.
ARC
57
Feb 21, 2022 10:54 AM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
JFortner5
Aug 20, 2015 06:13 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
oharajo
Jul 18, 2015 09:24 PM
