6.0L timing
Old Apr 11, 2003 | 10:37 PM
GF7PE's Avatar
Default 6.0L timing
Does it make sense that a 02 6.0L has 11.5* of timing at wot? Removed the maf screen and got it up to 13.5. Cruising was 49.5* of timing. I remember hearing that the sweet spot is 26-28*
Old Apr 13, 2003 | 06:30 PM
GF7PE's Avatar
Default Re: 6.0L timing
anyone? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 13, 2003 | 08:08 PM
BigTex's Avatar
I realy don't know your truck and your mods, but I can give you an idea. Timing at low rpms / low throttle is usually very high. AS you hit more throttle, the timing usually is less. I can think of 2 reasons you have such low timing: One, you are having knock retard that is pulling timing out, or you are in area of the PCM that has low timing by default. I had both of these issues. I was flowing more air than GM though it would ever do, so instead of a nice mid-20s timing number, it was something like 15. A tune can fix it. Custom tune, LS1 edit, or maybe even a handheld programmer.
Old Apr 17, 2003 | 05:32 AM
GF7PE's Avatar
I have an airaid intake on it, I wonder if I put the stock one back on if it would help? Makes me think no because I gained 2* at wot when I removed the maf screen. Oh yeah, auto tap said zero knock retard
ARC
57
Feb 21, 2022 10:54 AM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
JFortner5
Aug 20, 2015 06:13 PM
Denali08
Aug 9, 2015 04:34 PM
oharajo
Jul 18, 2015 09:24 PM
