6.0l Swap info
Old Jan 16, 2006 | 06:47 PM
4.8ForNow's Avatar
Default 6.0l Swap info
I have a 2000 rcsb with a 4.8l it is getting ready to become an extra car and not an every day driver. . My truck has 165,000 miles and I am hesitant to do anything to the motor that is in it now. I have been reading about the 6.0L swap and would like to get some info on how hard it will be to do. I work for a ford dealer in the parts dept. so getting parts will not be problem. Knowing what I need to get will be. If any one has any insight they would like to pass on I would be very grateful.
Old Jan 16, 2006 | 08:08 PM
Get new 6.0L engine install where 4.8L engine was and reprogram the computer and you are on your way (all the engine accessories are same.) Just make sure you don't get 99 6.0L because the crankshafts are longer and will cause problem with your tranny.
Old Jan 16, 2006 | 08:41 PM
quicksilverado's Avatar
Like cb said, its as simple as pulling the old motor out swaping the accesories and putting the new one in. Then all you need is the pcm retuned. It will run on the stock tune, but not as well as a retune.
Old Jan 17, 2006 | 05:06 AM
CashDudeHomie's Avatar
Make sure the spacer comes out with the old flywheel when you switch them. Also you probably need to switch over the oil pressure sending unit. It's behind the intake. Be careful, it's cheap plastic and I broke mine (50 bucks)
Old Jan 17, 2006 | 06:35 AM
white1's Avatar
Take 4.8 out, put 6.0 in, enjoy.
P.S. buy stock in goodyear
Old Jan 17, 2006 | 10:39 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Dont get an 00 6L either I have heard of people having problems with the crank also. Build a stroker motor while ur at it so you dont ahve to worry about the crank
Old Jan 17, 2006 | 10:41 AM
1slow01Z71's Avatar
I see you are from the Houston area you should come ot our get together in March here is the link would be cool to have you there
https://www.performancetrucks.net/fo...d.php?t=353961
Old Jan 17, 2006 | 01:39 PM
4.8ForNow's Avatar
thanks for all the info after doing some reading last night i am sure that im going to do a 6.0l swap. i did some calling a round and found a 2003 2500hd 6.0 with 23000 miles on it for 1700. question is this going to be a lq9 or do i need to find a caddy donor.
Old Jan 17, 2006 | 01:47 PM
beefshreadder116's Avatar
question regaurding 6.0L swap how much more does the 6.0 wiegh than a 4.8L
Old Jan 17, 2006 | 02:11 PM
4.8ForNow's Avatar
thanks for the invite ill will try to make it. i would like to see how one of these trucks run.
