6.0L questions?
Old Dec 12, 2003 | 01:58 AM
blacknight02's Avatar
Default 6.0L questions?
Does anyone know where i can order a brand new 6.0L from that isn't going to break me. Also, what heads and cam set ups have ya'll been using, getting the best results.
Old Dec 12, 2003 | 09:21 AM
OBXMarine's Avatar
You can check the classified section, get a new one from the dealer, or I even hear you may even be able to obatain a used 6.0 with piston slap from the dealer for a discount. Ebay is also popular. My guess for prices is 2-3k.
Old Dec 12, 2003 | 10:37 AM
Steve Bryant's Avatar
LS1 Tech Veteran
Default Look at this!
Check this out. This may be your solution. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448149511. This guy sells on ebay all the time. He bids on stuff from GM every week (they have a truck assembly plant there in Oklahoma City, OK).
Old Dec 12, 2003 | 01:07 PM
just use your throttle body instead of the one that comes with the motor, and dont use your PCM, not the one that comes with that motor, if it does come with one
Old Dec 12, 2003 | 01:23 PM
slow4.8's Avatar
so could I use the 6.0 long block and use my 4.8 intake and elect. including the PCM?
Old Dec 12, 2003 | 01:47 PM
ranwalk's Avatar
Everything is a direct swap and interchangeable. You will need to get your PCM tuned for the 6.0 for it to run it's full potential.
mikeyjm1
17
Oct 29, 2015 11:04 PM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
jleews6
Sep 8, 2015 10:17 AM
