6.0l Lq4
Old Feb 3, 2006 | 12:36 AM
BigMike9009's Avatar
Default 6.0l Lq4
ok i got my 6.0L but i havent dynod it. I heard the lq4 has 345 to the crank but what does it have to the ground? and same goes for lq9....
Old Feb 3, 2006 | 12:44 AM
TravisH's Avatar
i think its the LQ9 that has 345 to the crank probly puts down close to 300 at the wheels.
I belive the LQ4 was rated at like 320fwhp? mabye puts down 275rwhp
The rwhp numbers are also detirmined by the drivetrain a little, I heard the 80e takes up like 25hp more compared to the 60e or 65e..
Old Feb 3, 2006 | 12:55 AM
Colby 04's Avatar
The LQ4 should have 300HP and 360lb/ft of torque(at the crank). I think the 4L80E has a "longer" 1st gear(2.48 gear) than the 4L60E(3.06 gear), so off the line won't be as good with the 4L80E, but the increase in torque with the new 6.0 should make up for that. I've heard the same, the 80E eats more horsepower.
Old Feb 3, 2006 | 10:16 AM
JBT's Avatar
JBT
But why do GM rate the lq4 in the suburbans to 335hp then?
Old Feb 3, 2006 | 10:32 AM
6.0caddy's Avatar
i made 310 rwhp and 360 ft lbs to the wheel with stock LQ4 out of a 01 denali, with tune and no cats.
Old Feb 3, 2006 | 10:57 AM
Colby 04's Avatar
If I remember correctly, BigMike9009 purchased a 2001 engine/tranny.
So here's your answer:
Originally Posted by Trucktrend.com
2001 Silverado 2500 4x4 wants more power
Q: I own an 2001 Silverado 2500 4x4 with extended cab and 3.73:1 rearend. It's rated at 300 hp and 360 lb-ft of torque. While my truck has great power and performance, I note other GM models have this engine with higher power ratings (Sierra C3: 325 hp; Yukon Denali: 320 hp; and Escalade: 345 hp). Can you identify what GM has done to increase the power for these versions of the Vortec 6000 engine? I tow a 29-ft fifth-wheel trailer weighing 7700 lb, and while my truck seems to handle the job well, I wonder if there are some simple and relatively inexpensive things I can do to increase its power?
A: All the vehicles you've mentioned, with the exception of the Cadillac Escalade, utilize the Vortec 6000 LQ4 V-8 engine. The Caddy SUV is actually fitted with the Vortec HO 6000, option code LQ9, and uses a higher compression ratio, via a piston upgrade, which brings it up from the LQ4s 9.4:1 to a 10.0:1 ratio. This explains the significantly higher power rating of 345 hp at 5000 rpm. The Vortec LQ4 engines in the other 1/2-ton GM light-duty trucks, such as the Sierra and the Yukon, only have a slight horsepower variance. The plus or minus five horsepower is due to the different exhaust systems and air intake configurations in each model. Now here comes the tricky part. Your Silverado 2500 is considered a heavy-duty truck due to vehicle weight and therefore falls under certain federal regulations, one of them being the Transportation Equipment Noise Emission Controls. There was a problem with the Chevy and GMC 3/4- and 1-ton trucks equipped with the 6.0L V-8 engine producing excessive noise. Your truck's LQ4 engine actually had its potential horsepower downgraded. It now peaks at 300 hp at 4400 rpm because it was too noisy and would have failed the test pushing more horsepower at a higher rpm. According to the General Motors Engineering Communications Department, there were also driveability concerns involved with the decision, and the downgrade was accomplished through various means including the programming of the powertrain control module. One of the experts in GM performance reprogramming is Fastchip. You can log-on at www.fastchip.com or give them a call at 918/446-3019 for further details. You can pick up the K&N Generation II Fuel Injection Performance Kit to aid intake airflow for a few more horses. I also suggest not putting any money toward exhaust modifications on the 2500 series. The factory setup appears to have a good flow, and aftermarket performance systems are showing little or no advance in power.
Old Feb 3, 2006 | 11:11 AM
EXTREME's Avatar
interesting...
Old Feb 3, 2006 | 11:42 AM
white1's Avatar
Yes it is interesting. I wonder how mutch more power Im loosing to the wheels than a 2wd, just from going through the T-case.
Old Feb 3, 2006 | 12:52 PM
Zick's Avatar
http://forum.ls1truck.com/index.php?showtopic=4726
Hello Guys, last Friday when I picked up my engine, I had a 6L waiting for me on the dyno to tune. It's a completely stock engine with no mods, right out of the crate.
This engine put out 311HP and 351TQ on the first pull.
I wanted to see what timing did as it was increased:
Stock - 14-16degs : 311hp/351tq
Tuned- 20 degs : 350hp/380tq
Tuned- 25 degs : 356hp/390tq
Tuned- 30 degs : 357hp/392tq
Fully tuned with a/f ratio and max timing of 31 degs:
367HP/401TQ
Gains: 56HP/50TQ
There might have been a few more ponies left if we leaned it out just a few more points, but their wide-band wasn't working right.
Next time: stock 6.0L with 224/228cam and
FAST intake vs Truck intake.
btw just an fyi, the last 6L I tuned down there was an LQ9 that put out 441hp with a 224 cam, I was mistaken, I told you guys it was an LQ4.
later,
allen
Old Feb 3, 2006 | 04:11 PM
EXTREME's Avatar
Question
that was also done on a engine dyno correct. Wonder what % of hp loss there is on a lq4 like that one, going thru an 80 trans, transfer case, and 14bolt?
