6.0l cam
Old Jun 19, 2013 | 09:20 PM
farmrowe1's Avatar
Default 6.0l cam
so I have the stuff in my sig and am going to have 4.56 gears, a 2800 rpm stall, a whipple with the injectors it comes with, and after everything is done a BB tune, I need help though!! any calls on a cam, what kinda springs, should I get, push rods? just tell me what to get, I don't know enough yet but I am trying to learn, also any ideas for fuel pump, and should I do any internal work? like heads, piston, rods? anything that yall think would help.
Btw yall are the best and have been a ton of help and im sure other such noobs like myself would agree
Old Jun 19, 2013 | 10:05 PM
Jake99's Avatar
Id go with a cam from stock48 on this forum, im guessing something in the 212-220 range and he can hook up with the springs and pushrods aswell. The motor is else wise ready to eat some boost, up to 14psi or so then you will need head studs. Also need to upgrade to 80lb injectors and a walbro 430 fuel pump.
Old Jun 20, 2013 | 07:10 AM
farmrowe1's Avatar
alright thank you, how would I get in contact with him to figure something out? and a set of arp head studs? im not sure what size they are but the whipple comes with a set of injectors so I figured I would just use those, il def check out that pump though! thank you
Old Jun 29, 2013 | 01:55 PM
Gmaximus's Avatar
Whatd you end up going with for a cam? Im thinking about a 212 218 low lift after I put my pro charger on
ARC
57
Feb 21, 2022 10:54 AM
2500ZL1
Jan 25, 2016 06:30 AM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
Denali08
Aug 9, 2015 04:34 PM
oharajo
Jul 18, 2015 09:24 PM
