6.0 won't start
Old Sep 17, 2016 | 11:07 PM
dswitzer9865's Avatar
Registered User
Default 6.0 won't start
Hey guys, having a helluva weekend. Did knock sensor replacement and that was successful. Took 2002 2500 out for a few burnouts and everything was fine. Parked it for a couple hours. Jumped in it and I can hear the starter ticking rapidly. Put battery charger on it and it won't start. Replaced starter, battery shows 13.5 volts on volt meter. I am going to get a new battery now. Anyone have any suggestions?
Old Sep 17, 2016 | 11:14 PM
FFDP's Avatar
Bad ground is a good guess.
Old Sep 18, 2016 | 07:48 AM
Brettk's Avatar
If the battery is showing 13.5 volts with the motor off then something is wrong.
I bet one of the cells in the battery is shorted out and a new one will fix it
Old Sep 18, 2016 | 03:14 PM
MrHorsepowerLSx's Avatar
11 Second Club
Are battery terminals clean and tight, and a battery that just came off of a charger will show anywhere between 13.5-14.4 volts, that's is just a "surface charge" turn all the lights on and then load test the battery and read the voltage. You didn't break the small grounding wire next to the oil pressure sender did you? Or leave the ground loose?
Old Sep 19, 2016 | 03:03 PM
Registered User
It was a bad battery. Feel kinda dumb.
i was surprised the truck refused to start off of a 200 amp wheeled battery charger/engine starter. Even hooked the box up to the battery cables and it refused to start. Fresh battery and everything worked flawlessly.
thanks guys
Registered User
thanks guys
Area47
Sep 20, 2016 08:12 PM
2ToNe04
Sep 19, 2016 09:44 PM
r44guy
Sep 19, 2016 01:58 AM
busted33
Sep 13, 2016 10:11 AM
blake2kz71
Sep 8, 2016 03:38 PM
