6.0 swap complete, have problems w/questions
#52
I know it somewhere on the forum if you search but I'm sure the 4.8 used 24lb and the 6.0 were 26lb. Not enought to make any difference because even 24lb injectors will be enough for a 6.0 until you start adding mods like cam, heads, etc.
I might have missed it but is the LQ9 stock or modded? I'm sure it's just in the tune.
I know my LQ9 felt way underpowered compared to the 5.3 when I first put it in but a good tune made all the difference in the world.
Also, I didn't realize the 6.0 had bigger injectors. I still have the 6.0 injectors with me though so I could put them in. I plan on adding a cam soon. Will the 24.7lb/hr injectors not be enough?
#53
Just did a quick search, looks like I was wrong.
https://www.performancetrucks.net/fo...ight=injectors
01+ 4.8/5.3/6.0 used 24.7lb injectors. The 8.1 used 31lb.
You should be fine if you don't have any bolt ons or mods.
#54
