6.0 swap complete
Old Jun 30, 2004 | 10:09 AM
greentahoe's Avatar
How much boost are you seeing??
Old Jun 30, 2004 | 11:20 AM
bigguy75inches's Avatar
about 3 lbs i think. i was seeing 6psi with the5.3, but i probably lost the psi due to the larger motor, and cam.
Old Jun 30, 2004 | 11:34 AM
i keep showing a lot of rich correction on my long fuel trims and short fuel trims while driving around at 2000 rpms. when i nail it. both the short and long fuel trims are at 0. On bank 1 sensor 1 oxygen sensor it averages a .579 it will go to around .700 or .800 then drop to like .030 and then go back up and down while cruising. when i mash the gas, its around .900
Old Jun 30, 2004 | 12:30 PM
rgvsierra's Avatar
ltft are at 0 @ wot and 900mv @ wot, looks good there.. donnt worry how the fluctuate during cruising,
Old Jun 30, 2004 | 12:31 PM
Yelo's Avatar
don't bother trying to tune from the stock 02's....they will tell you nothing except that there is fuel in the exhaust !!
Old Jun 30, 2004 | 12:51 PM
hmmm,, got my idle fixed, i just cranked on the screw and ajusted teh set screw so the throttle sensor read 2.4 percent, then i unhooked the sensor, turned the truck on, turned the truck off, and hooked the sensor back up, and bam it reads 0 persent, and it idles perfectly. now if i can just find out where my power is goin. my fuel pressure was above 60 psi at wot in first gear. so i got plenty of pressure.
so something else must be the culprit. or else i just spent over 2 grand on a 6.0, cam, stall, and lost a second in the quarter!
Old Jun 30, 2004 | 12:53 PM
my 43 # injectors are tuned to 5.15 across the board. is that about right? my whipple computer is unhooked, but i have yet to do the bypass valve mod. im fixin to do that.
Old Jun 30, 2004 | 12:55 PM
anyone want to look at my tune? i got till tonight to fix this puppy. i got a road trip tomorrow. my truck seem to run fine, just way underpowered. im fairly sure a stock 5.3 could out run me
Old Jul 1, 2004 | 01:27 AM
HAZE's Avatar
it's your timing. it needs to be increased quite a bit. e
Old Jul 1, 2004 | 06:51 AM
parish8's Avatar
single digit dreamer
yep, do a log on your timing and let us know what it is doing.
log these things.
timing
knock retard
rpm
throttle pos
b1s1 o2
b2s1 02
speed
oder a 3/8"-1/2" smaller pully too. your giving up alot of power there.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Oobray
Jun 13, 2022 03:38 AM
OHsixLS3
Dec 27, 2016 09:30 AM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
