6.0 swap
ok my truck is feelin kinda tired around 150k so i have some ideas and need some input. i was thinking of doin the following:
6.0 swap
TSP 225 cam
E-fans
Pacesetter LT headers and ORY into magnaflow dumped out
Cats welded into ORY for emissions
Any input or advice?
6.0 swap
TSP 225 cam
E-fans
I am building a 6.0 now and will just swap it out. That way I can build it a little as I go and research the parts. If you are thinking about pulling your motor I would start to build a back up plan now.
I would mod your truck as is then save up for a motor and jump in. the build itself is a lot more extensive than you would think on the surface. Trans, DS, little things like connectors, then you need to make sure the motor runs, get any machine work out of the way, then do the internals/heads before you put it in. Basically make sure you can do everything up to tune before you drop it in.
Not trying to deter you but its some work, Im in a little over my melon myself so I need to relax about it for a little while
GrooveCityZ71
Aug 31, 2015 12:05 PM
