6.0 questions?
Old May 2, 2005 | 08:22 PM
01z71's Avatar
Talking 6.0 questions?
This summer I am planning on dropping a 6.0 lq4 or lq9 into my 01 z71 standardcab stepside and was wondering from all the guys that have done this if you went with a complete engine or just the block and heads? Does everything transfer over if I get just the block and heads? Also where can I get a good price on a 6.0? What kind of money am I looking to spend to have this installed?
Old May 2, 2005 | 08:54 PM
99Silver6.0's Avatar
I went complete. Didnt want to rebuild one. I wanted a good runner to put in. Check on www.car-part.com for a motor. Great place to start. Motor will run anywhere from 1000-1500 for a full LQ4. Even more for a complete LQ9. Im not sure what the going rate is to install the thing. Somebody will chime in on that. Im doing my own install.
Old May 2, 2005 | 11:27 PM
LedFut's Avatar
14 Second Truck Club
I did heads and cam on my motor before it went in. But i know i paid about 1500 for a complete LQ4. It had everything, right down to the oxygen sensors. I ended up using my stock 5.3L computer, as the LQ4 has a drive-by-wire throttle body, and you would have to rewire for that. You'll probably end up doing the same thing. Before you drop the motor in, at least put in a cam. You will NOT regret it.
If you get someone to do the install, look for labor rates up close to $2000. Id suggest doing it yourself, its not very hard at all.
Old May 3, 2005 | 12:51 AM
01z71's Avatar
Thanks for the web address, but what kind of miles are you guys getting on the complete engine for $1000-1500?
Old May 3, 2005 | 03:32 AM
sfj
pretty high miles but people here have sprayed the **** out of motors with over 100k on them and been fine these motors are the bomb just only the trannys suck which i have not experienced until here lately
Old May 3, 2005 | 07:50 AM
LedFut's Avatar
My motor had about 45,000 on it. I replaced the main bearings in it and checked oil clearances however, just to be safe.
Old May 3, 2005 | 08:07 AM
rosscob's Avatar
If you are patient you can find a fairly low mile engine for that much $.
ferrellrooster
Mar 6, 2025 03:22 PM
spiritfish
Aug 23, 2015 09:58 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
USMCvet0311
Aug 1, 2015 07:45 AM
justuc
Jul 24, 2015 11:52 PM
