6.0 Pinging S.O.B.
Old Apr 29, 2002 | 11:16 PM
Jr's Avatar
Jr
Default 6.0 Pinging S.O.B.
I Have a 2001 chevy h.d. with the 6.0 liter that i pull a trailer with. When the motor is under a load (with 91 octane) it pings pretty bad. Any suggestions. Also i have a 20ft trailer and am getting ready to invest in a 30-32ft will the 6.0 handle it??
Old Apr 30, 2002 | 12:39 AM
really slow truck's Avatar
Default Re: 6.0 Pinging S.O.B.
is this a stock 6.0L? you dont have hypertech or anything on it do you? thats weird if it is something that always happens without advancing timing any and ruling out bad gas
if not id be taking it for a little check up for sure
Old Apr 30, 2002 | 08:26 AM
GTO Forum Director
Check for vacuum leaks around the intake plenum and PCV lines. It could be running too lean due to a vacuum leak therefore causing some pinging.
Or your EGR isn't turning on.
Old Apr 30, 2002 | 09:04 AM
BigTex's Avatar
CMNTMXR57 - Tell me a little about that EGR function please. Are you saying that under engine load, the EGR will turn ON and that will reduce pinging?
Old Apr 30, 2002 | 09:28 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Have you tried any octane booster?
Old Apr 30, 2002 | 09:57 AM
GTO Forum Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigTex:
<strong>CMNTMXR57 - Tell me a little about that EGR function please. Are you saying that under engine load, the EGR will turn ON and that will reduce pinging?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Unless you are at WOT, the EGR system turns on and injects exhaust gas into the incoming air stream to be re-used. It helps richen up the mixture a little without having to dump more fuel into the combustion chamber.
Most pinging occurs from throttle tip in to midthrottle application where load is being placed on an engine, this is where the EGR system should be doing it's job.
I forget the exact criteria for it to turn on, but I know it was part of my Knock Retard problem at throttle tip in through mid throttle that I had becuase Ed Wrong had turned it off in my PCM. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Apr 30, 2002 | 11:30 AM
BigTex's Avatar
Thats why I asked. I have the whole EGR assembly sitting on a shelf. Turned it off w/ LS1 edit.
I have KR at throttle tip in below 2000 RPMs. It is most noticeable at freeway speed w/ converter locked up. I pulled alot of timing out at those RPMs w/ no success. I completely removed converter lockup last week. That just about fixed it, but that will probably fix my gas mileage too.
So there is a good reason to have the EGR installed. What about 02 trucks and the vette? They dont have EGR. Do they have this problem?
Old Apr 30, 2002 | 01:28 PM
graygmc's Avatar
richard what is your gas mileage now without an egr. i notice mine went down like 1 or 1.5 mpg when i had it unplugged. so i decided to just leave it alone.
Old Apr 30, 2002 | 01:36 PM
GTO Forum Director
There is, but if you have it turned off in the PCM it should be a moot point.
But then again, the engine itself doesn't know that. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 30, 2002 | 02:39 PM
BigTex's Avatar
Not sure on the gas mileage. I feel like it is an ever-changing, always evolving project. I cant leave it alone, so I have no idea how the EGR by itself effects gas mileage.
I think I will throw the EGR back on sometime and see what happens.
