6.0 (LQ4) Compression Question
I have had people tell me around 10:7.1 or 10:8.1 on good pump gas,no more than 11:1.1. This is what I have been told. I have been asking the same question. I am upping the compression with my new heads on my SS.
Originally Posted by rob3379
I need to know what would be a good compression or the max on pump fuel 6.0?
Thanks,
Rob
Thanks,
Rob
Philip S.
I just went through all this with trying to figure out how much I need to take of my 5.3 heads, they're are some calculators online that can figure it out.
You need to know stock combustion chamber size, deck height, bore diameter and stock comression. I might be forgetting one though
do a search for comression ratio calculator read up
After not getting any real clear results or answers I just gave my heads to the machine shop and said you figure it out this is what I want my compression at
Originally Posted by mattrem
I know that with the LQ9 ( flat top pistons) If you were to use 68cc heads you are about 10:8. I don't even know the c/r on the LQ4. What is it? 9 something?
GrooveCityZ71
08-31-2015 12:05 PM
