6.0 with L92 heads
Old Jun 18, 2016 | 11:55 AM
terravast4's Avatar
Default 6.0 with L92 heads
theres a 6.0 for sale with L92 heads that came out of a 2006 van. He says the oil pump started going out on it. its for $300. I think this would be a good opportunity for my first build. if it lost oil pressure it should be able to be bored out to clean it up right?
Old Jun 18, 2016 | 12:19 PM
Wolftrk99's Avatar
So long as it didnt seize cam up in a bearing or starve the mains/rods you should be fine.... Id make sure it turns over first....$300 isnt bad for it though, if all in fact it needs is to be gone through and an oil pump
Old Jun 18, 2016 | 12:54 PM
terravast4's Avatar
i plan on a full build for boost. it will be bored out anyway. looks very reasonable compared to the prices I've seen around here
Old Jun 18, 2016 | 01:20 PM
Wolftrk99's Avatar
Id jump on it.... Just make surenit turns over before you buy it and if they let you take timing cover off to just be sure everything is turning and they havent pulled timing chain or something stupid...
Old Jun 18, 2016 | 01:27 PM
ezdaar's Avatar
Heads are worth 300.
Old Jun 18, 2016 | 01:42 PM
Wolftrk99's Avatar
True but is it worth getting a fubar block just for heads unless theyll sell just the heAds...id be a littl concerned about the fact its an 06 with rectangular port heads.... Unkess someone has already converted it...
Old Jun 18, 2016 | 06:04 PM
Fast355's Avatar
It should be worth that for parts alone as a core. Provided its not locked up and did not spin any bearings.
Old Jun 18, 2016 | 11:26 PM
parks450's Avatar
As long as it didn't throw a rod and screw the block and heads up it's worth $300. The accessories along are worth that, heads are worth that as well. Either way it's a good deal.
Old Jun 19, 2016 | 12:37 AM
Wolftrk99's Avatar
Never said it wasnt a good deal.... just saying go through it to make sure its not fubar before buying it...
TxStVanWilder
May 23, 2016 06:40 PM
booboo37
Apr 10, 2016 06:26 AM
70ls1chevelle
Apr 6, 2016 09:29 PM
AM18195
Mar 30, 2016 08:59 PM
