6.0 issues
Old Nov 4, 2012 | 07:30 AM
99mpg's Avatar
Default 6.0 issues
Most likely there is a write-up I went 3 pages back couldn't find one.
I just got a 07 3500 6.0 fleet side
With a ton a miles. 287,
My problem is the lifter will tap,loose power of course then go away and back to normal.
I've done a little research and seen about this o-ring issue.
But I rather change the oil pump at the same time.
Has anyone had these issues let me know... Thanks.
Old Nov 4, 2012 | 08:32 AM
03sierraslt's Avatar
What does your oil pressure do when this happens? What is your idle oil pressure and WO oil pressure?
Old Nov 4, 2012 | 11:06 AM
99mpg's Avatar
Just now I was in the truck at idle and it dropped low.
I gave a little gas and it built pressure again... I know the pump is bad and that o-ring too any how to write ups?
Old Nov 4, 2012 | 11:08 AM
99mpg's Avatar
And wo is around 42-44 at idle its under 40.
greedygenius
Sep 3, 2015 06:51 AM
smokeshow
Aug 23, 2015 08:23 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
Abuckeye
Aug 19, 2015 06:11 PM
05GMC4.8
Aug 7, 2015 09:55 PM
