6.0 headers ?
Old Nov 1, 2005 | 11:28 AM
Mangled03gmc's Avatar
Baltimore Whore
Default 6.0 headers ?
Can you use 4.8, 5.3 on a 6.0 or do i need to get a set just for the 6. Thanks people.
Old Nov 1, 2005 | 11:39 AM
budhayes3's Avatar
PT's Slowest Truck
If you're gonna be getting long tubes that require y-pipe fabrication anyway, they should all be the same. If you're going with direct bolt-in shorties (which I recommend against, I know from personal experience that they're not worth the $$), they are different. The 4.8-5.3's have a different y-pipe with a different flange on the passenger's side than the 6.0's. 6.0's have dual pipes that run from the manifolds to the muffler.
Old Nov 1, 2005 | 09:42 PM
Baltimore Whore
I have the Lt pace setters on my 4.8 and was wondering if I could use them on a 6.0 or ls1. Wasn't sure if the exhaust ports were the same.
Old Nov 1, 2005 | 09:48 PM
budhayes3's Avatar
PT's Slowest Truck
Yep, you should be able to swap in a 6.0 and re-use your PaceSetters
Old Nov 1, 2005 | 11:52 PM
they will bolt right up
Old Nov 2, 2005 | 04:05 PM
Baltimore Whore
Beautiful, thanks guys
flatblack83
Sep 7, 2015 07:52 PM
greedygenius
Sep 3, 2015 06:51 AM
Layn22s
Aug 31, 2015 03:43 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Azim05
Aug 27, 2015 05:33 PM
